First post, by Guest
Hello -
I've used DOSBox for quite some time on my laptop with no problems. However, putting it on my desktop has a problem, only in fullscreen mode. It works perfectly in a window, but in fullscreen the monitor brings up a message that says "Out of frequency range: Attention out of range H:29.1KHz V:69.9Hz".
This is on a Dell Dimension 2400, with an Intel 82845G/GL/GE/PE/GV adapter and a generic monitor, running Windows XP Home with SP2.
-Steve
Reply 1 of 1, by eL_PuSHeR
Try setting a compatible resolution using Fullfixed=true and the Fullfixed resolution under dosbox.conf
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
