First post, by cubias
hi, im not very good with computers, so could someone please explain how to use dosbox simply and not in computer talk please?
1.- Read the readme file. It can't be that difficult to understand. Doesn't it?
2.- Read the newbie guides located somewhere on this forum.
3.- If you don't feel comfortable using command-line, you should get some GUI (frontend) for DOSBox. D-Fend, RobyDOSBox, etc...
If you still have queries, post back and we will try to help you.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
_________________
Computer talk
"0101011101101000011000010111010000100111011100110010000001110100011010000110010100100000011011010110000101110100011101000110010101110010001000000111011101101001011101000110100000100000001000100110001101101111011011010111000001110101011101000110010101110010001000000111010001100001011011000110101100111111001000000100100001100001011100100110010000100000011101000110111100100000011101010110111001100100011001010111001001110011011101000110000101101110011001000010000001101111011100100010000001110011011011110110110101100101011101000110100001101001011011100110011100111111"
Here, let me translate that into something more readable:
16CB:0100 66 DB 6616CB:0101 55 PUSH BP16CB:0102 66 DB 6616CB:0103 8BEC MOV BP,SP16CB:0105 66 DB 6616CB:0106 81E5FFFF AND BP,FFFF16CB:010A 0000 ADD [BX+SI],AL16CB:010C 1E PUSH DS16CB:010D 06 PUSH ES16CB:010E 66 DB 6616CB:010F 53 PUSH BX16CB:0110 66 DB 6616CB:0111 56 PUSH SI16CB:0112 66 DB 6616CB:0113 57 PUSH DI16CB:0114 B990A4 MOV CX,A49016CB:0117 C1 DB C116CB:0118 E9048C JMP 8D1F16CB:011B C8 DB C816CB:011C 03C1 ADD AX,CX16CB:011E 8ED8 MOV DS,AX
Intel i7 5960X
8 GB DDR4 (2100)
