First post, by Guest
Compared to most of the peeps here, I am a newbie to DOS. I started with computers in 1996 with a win 3.11 computer. However let me get directly to my problem.
I have X-com Terror from the Deep and Enemy unknown and was able to play them in WinMe which still had DOS in it. I got a new laptop with WinXP and couldnt play it. I did some research on the net and found that some peeps had had the same problem and found a solution; DOSBOX 😀.
Happily, I have downloaded the Win32 DOSBOX.exe. I have tried to install it but it will not work. It gives an error. The error is titled 16-bit MS-DOS Subsystem. The NTVDM CPU has encountered an illegal instruction. CS:0f81 IP:0119 OP: 65 63 74 20 61.
I have a HP Athlon XP-M laptop running Win XP SP1 with 192 RAM 64MB graphics.
Can anyone offer any advice?
Thanks in advance..
