First post, by Ender1987
I'm trying to run Crusader: no regret and when when I try to play I always get "Not enough memory extracting IDATA\file_id.diz"
Any help would be appreciated.
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
"file_id.diz" - sounds more like you have downloaded the game somewhere and the selfextracting archive is not happy about the dosbox environment. What happens if you try to run it outside of dosbox?
