First post, by Guest
I have the correct path mounted but when I attempt to run the exe I get the following message.
"This is a windows 95 executable."
And nothing happens. I checked the compatibility under properties and it wasn't turned on. I've tried turning on the compatiblity and tried it under both windows95 and 98 and neither worked.
System:
WinXP home
p4 1.8ghz
640mb ram
geforce4 ti 4200
