First post, by somecn
My machine
Athlon64 2800+
512M Memory
ATI Radeon 9600
ALC655(AC97)
When DOSBOX has been started, CPU load raises up to 100% immediately,
I do nothing but leaving it at the prompt "Z:\"
sound stutters seriously if game is running
However, another machine
using Celeron 2.4G CPU,
Integrated Video Chip
256M Memory
...runs regularly!
Both of them run Windows2000Professional
who can tell W H Y ?
It would better not be the problem of compatibility with AMD64 CPU
I hope
Reply 1 of 8, by DosFreak
Check that you have FULL acceleration enabled for your video card.
Change output= in dosbox.conf to surface.
Make your games work offline
Reply 2 of 8, by MiniMax
Rank Moderator
Moderator
Also check your screen resolution and bit-depth. DOSBox/SDL do not like 24-bit mode if I remember correctly.
_________________
Reply 4 of 8, by Guest
Thanks for your attention
I have tried output= in dosbox.conf with surface, ddraw and opengl
none of them could resolve this
my video card is already set FULL acceleration
32bit color depth
I found that I could play by setting frameskip to 2
while cpu load was near 70%
Is there anyone using AMD 64-bit CPU or suffering the misfortune like mine?
somecn
Reply 5 of 8, by MajorGrubert
I am able to run DOSBox in my Atlhon64 without trouble, but under Windows XP. Do you really have to run Windows 2000, or is XP an option?
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
Reply 7 of 8, by DosFreak
I doubt this is an OS problem. More likely video. Which ver of the ATI drivers are you using? Latest Catalyst is 5.4.
