Serial Issues
First post, by caltrop
DOSbox serial has always been an issue with all my systems
back through Mint Mate 18.1
it is erratic at best, sometimes working, most times not
I use several programs that require serial interface through DOS:
HP48 PDL & HP version of Columbia University Kermit Transfer
Windows XP requiring serial works flawlessly in the virtual machine
only DOSbox has issues
then there is the MIDI issue...
which makes old DOS worthless
I even set the irq & port
serial1=directserial realport:ttyUSB0 irq:4 port:0x3f8
#serial2=directserial realport:ttyUSB1 irq:3 port:0x2f8
crw-rw----+ 1 root dialout 188, 0 2022-05-11 21:18 /dev/ttyUSB0
chmod to all read write
crw-rw-rw-+ 1 root dialout 188, 0 2022-05-11 21:18 /dev/ttyUSB0
serial status using various utilities:
Bus 001 Device 108: ID 2478:2008 Tripp-Lite U209-000-R Serial Port
/dev/ttyUSB0, UART: 16654, Port: 0x0000, IRQ: 0
MAJOR 188
MINOR 0
ID_PCI_CLASS_FROM_DATABASE Serial bus controller
ID_PCI_SUBCLASS_FROM_DATABASE USB controller
ID_PCI_INTERFACE_FROM_DATABASE XHCI
ID_VENDOR_FROM_DATABASE Tripp-Lite
ID_MODEL_FROM_DATABASE U209-000-R Serial Port
ID_SERIAL 2478_2008
ID_USB_DRIVER pl2303
groups: caltrop adm dialout cdrom sudo dip plugdev lpadmin sambashare
dosbox log file I created
$ dosbox > dosbox.log &
2022-05-11 20:52:58 Wed
DOSBox version 0.74-3
Copyright 2002-2019 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file /home/caltrop/.dosbox/dosbox-0.74-3.conf
MIXER:Got different values from SDL: freq 22050, blocksize 512
ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)
MIDI:Opened device:none
Serial1: Opening ttyUSB0
One joystick reported, initializing with 4axis
Using joystick STD AxisPad with 4 axes, 20 buttons and 1 hat(s)
Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0
Serial1: Errors: Framing 0, Parity 0, Overrun RX:21 (IF0:0), TX:0, Break 0
Serial1: Errors: Framing 0, Parity 0, Overrun RX:14 (IF0:0), TX:0, Break 0
Reply 4 of 11, by caltrop
here we are in 2023 with a newer system & newer Mint Mate and the serial issues persist
it sometimes works, mostly not, something is causing serial communication to fail in DOSBox
    DOSBox   0.74-3
OS Linux Mint 20.1 ulyssa
Kernel GNU/Linux 5.4.0-153-generic x86_64
Kernel ver #170-Ubuntu SMP Fri Jun 16 13:43:31 UTC 2023
Desktop MATE Desktop Environment 1.24.0
Bash 5.0.17(1)-release x86_64-pc-linux-gnu
Mono Font DejaVuSansMono.ttf: "DejaVu Sans Mono" "Book"
all TTY permissions are changed prior to starting DOSBox
ID_VENDOR_FROM_DATABASE Future Technology Devices International, Ltd
ID_MODEL_FROM_DATABASE FT2232C/D/H Dual UART/FIFO IC
/dev/ttyUSB0, UART: unknown, Port: 0x0000, IRQ: 0
crw-rw-rw-+ 1 caltrop caltrop 188, 0 2023-08-05 09:10 /dev/ttyUSB0
/dev/ttyUSB1, UART: unknown, Port: 0x0000, IRQ: 0
crw-rw-rw-+ 1 caltrop caltrop 188, 1 2023-08-05 09:10 /dev/ttyUSB1
/dev/ttyUSB2, UART: 16654, Port: 0x0000, IRQ: 0
crw-rw-rw-+ 1 caltrop caltrop 188, 2 2023-08-05 09:10 /dev/ttyUSB2
DOSBox Config
serial1=directserial realport:ttyUSB0 irq:4 port:0x3f8 # COM1 Future Tech
serial2=directserial realport:ttyUSB1 irq:3 port:0x2f8 # COM2 Future Tech
serial3=disabled
serial4=disabled
Reply 5 of 11, by caltrop
LINUX UPDATE - 2023 quickly ending
currently using the Future Technology (no WinXP drivers) device for DOSBox
the Tripp-Lite (has WinXP drivers) device is dedicated to a virtual WinXP
but the device should not matter...
I've tried EVERYTHING and SERIAL still is intermittent at best
I now have EVERYTHING set to READ/WRITE
no more sudo chmod... now that I have rules.d
$ cat /etc/udev/rules.d/50-udev.rules
KERNEL=="ttyUSB[0-9]*", MODE="0666"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6010", MODE="0666"
SUBSYSTEM=="usb", ATTRS{idVendor}=="2478", ATTRS{idProduct}=="2008", MODE="0666"
SUBSYSTEM=="usb", ATTRS{idVendor}=="4102", ATTRS{idProduct}=="1007", MODE="0666"
$ lsusb-s.sh
│ List Select USB │
Bus 001 Device 015: ID 0403:6010 Future Technology Devices International, Ltd FT2232C/D/H Dual UART/FIFO IC
001 015 0403 6010
crw-rw-rw- 1 root root 189, 14 2023-09-17 11:28 /dev/bus/usb/001/015
Bus 001 Device 016: ID 2478:2008 Tripp-Lite U209-000-R Serial Port
001 016 2478 2008
crw-rw-rw- 1 root root 189, 15 2023-09-17 11:28 /dev/bus/usb/001/016
$ ll /dev/ttyUSB*
crw-rw-rw-+ 1 root dialout 188, 0 2023-09-17 11:36 /dev/ttyUSB0
crw-rw-rw-+ 1 root dialout 188, 1 2023-09-17 11:29 /dev/ttyUSB1
crw-rw-rw-+ 1 root dialout 188, 2 2023-09-17 11:29 /dev/ttyUSB2
Reply 6 of 11, by davidrg
caltrop wrote on 2022-05-21, 14:29:
If you're still trying to run MS-DOS Kermit in DOSbox, have you considered not using DOSbox? Kermit is available for practically every platform under the sun so there is possibly no need to run the DOS version under an emulator.
On UNIX/Linux/MacOS X there is C-Kermit. Its available from the Debian/Ubuntu/Rasbian repositories and pretty trivial to build from source. And on Windows (nearly all 32bit and 64bit versions) and OS/2 there is C-Kermit for Windows, the successor to Kermit 95, which I maintain.
Instructions for using C-Kermit with HP48 calculators is available on The Kermit Project website here: https://www.kermitproject.org/hp48filetransfer.html. These instructions should work fine on the Windows version too as its based on the Linux/UNIX version.
Reply 7 of 11, by caltrop
here's the latest...
start dosbox
run program that uses serial
exit that program
run another program that uses serial
serial has QUIT working
so it's a one-off using serial communication in dosbox
why...?
EVERYTHING is read write
Serial bus controller|USB controller|XHCI|Future Technology Devices International, Ltd|FT2232C/D/H Dual UART/FIFO IC|
crw-rw-rw- /dev/ttyUSB0
crw-rw-rw- /dev/ttyUSB1
Serial bus controller|USB controller|XHCI|Tripp-Lite|U209-000-R Serial Port|
crw-rw-rw- /dev/ttyUSB2
Reply 8 of 11, by caltrop
got serial working in DOSBox... sort of...
Linux script runs DOSBox with a DOS batch command that then exits DOSBox
pld.sh -> dosbox -c pdl.bat & -> exit dosbox
repeat for more serial communication
make a shortcut & a click is all it takes
I can live with this one-off automated scripting system
SOMETHING LOCKS UP AFTER USING SERIAL COMMUNICATION ONCE
THEN DOSBOX NEEDS RESRARTING
KERNEL=="ttyUSB[0-9]*", MODE="0666", GROUP="dialout"
SUBSYSTEM=="usb", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6010", MODE="0666", GROUP="dialout"
SUBSYSTEM=="usb", ATTRS{idVendor}=="2478", ATTRS{idProduct}=="2008", MODE="0666", GROUP="dialout"
current configuration
$ sudo chgrp dialout /usr/bin/dosbox
-rwxr-xr-x 1 root dialout 2.6M 2020-03-22 10:38 /usr/bin/dosbox
crw-rw-rw- 1 root dialout 189, 14 2023-09-23 08:40 /dev/bus/usb/001/015
crw-rw-rw-+ 1 root dialout 188, 0 2023-09-23 08:40 /dev/ttyUSB0
crw-rw-rw-+ 1 root dialout 188, 1 2023-09-23 08:40 /dev/ttyUSB1
Reply 9 of 11, by caltrop
well... this is it for me posting about DOSBox Serial issues
got it to an acceptable level but it is still NOT right!
UPDATE 2023-10-16
it is truly a ONE-OFF SERIAL EXPERIENCE!
more than one instance of DOSBox running - serial quits!!!
recap:
run DOSBox once, use serial, then exit
do not run more than one instance of DOSBox
have all the permissions set to read/write
running Linux
Get Your Codes: there will be a long list...
$ lsusb
... 2478:2008 Tripp-Lite U209-000-R Serial Port
... 4102:1007 iRiver, Ltd. iFP-700 series mp3/ogg vorbis player
Set Your Rules - root access: /etc/udev/rules.d/50-udev.rules
REBOOT!
Check Permissions - if you want...
crw-rw-rw-+ what's that '+' ???
$ ls -l /dev/ttyUSB*
crw-rw-rw-+ 1 root dialout 188, 0 2023-10-15 17:27 /dev/ttyUSB0
crw-rw-rw-+ 1 root dialout 188, 1 2023-10-13 15:11 /dev/ttyUSB1
$ ls -l /dev/bus/usb/001/015
crw-rw-rw- 1 root dialout 189, 14 2023-10-13 15:11 /dev/bus/usb/001/015
Start DOSBox - with a command
#!/usr/bin/bash
dosbox -c pdl &
DOSBox - batch command
drive I: needs mounting in dosbox-0.74-3.conf
this happens to match my virtual Windows XP
which has no issue with serial communication
but is a pain to run & backup
rem PDL.BAT
@echo off
cls
i:
cd \pdl
rem pdl.exe
pdl
exit
yes I still use OLD serial stuff:
my old Garmin GPS's
my old HP48 SX(died)/G(auction find)/GX(college days)
the HP48 series is the BEST calculator ever made
the iRiver MP3 player is not really serial
but the program just would not work until I tried 'sudo ifp'
then I discovered '/etc/udev/rules.d/50-udev.rules'
I learned about system permissions in this SERIAL adventure
which allowed me to fix other stuff
but DOSBox is still ONE-OFF for SERIAL COMMUNICATION
Reply 10 of 11, by thp
Why do the chmod shenanigans and not just add your user to the “dialout” group? The device nodes are already group-read-writable by default.
Docs: https://wiki.debian.org/SystemGroups
Reply 11 of 11, by caltrop
USER is already in the DIALOUT group!
$ groups user
user : user adm dialout cdrom sudo dip plugdev lpadmin sambashare vboxusers
what I have done is the only thing that works
and it is still a ONE-OFF
anyway I quit chmod & use /system/etc/udev/rules.d/50-udev.rules to enable full access
start DOSBox
run a serial program
end that program
SERIAL COMMUNICATION QUITS
have to restart DOSBox
ONE-OFF SERIAL COMMUNICATION
