OK IM GETING SOMEWAY
i put in this in intro cdrom ,mount c"c then enter it said this
mount c c:\ windows mounts windows directory as the c drive in dosbox
Thn i put mount d D:\ t cdrom usecd ioct{
it said this drive d is mounted as local directory D:\ then i put
d: then enter
then i put dir entered
i found the installer there was install exe it went though some installing process then it said invalid directory name which was c
but i shouldnt have to install any way because the game is already installed in c directory
but i did your way too mini max
mount c "c:\ then entered it said mount c is installed in dosbox
then for D"D:\"-t cdrom-"iocl
but it said it installed c again but d:
Ace im listening and learning
