First post, by Longshot
😅 I'm sorry to ask what probadly is a noob question.
But i'm run in to a problem get Dos Box to work. I'm run the windows
version. It worked for the first couple of times untill i try to change the
setting for ems and xms. It had been loading as a small window in the
upper left side but after the change it's started to load in to full
screen and runs maybe to 2 sec before being shutdown. I've tried change
back to the default settings but that hasn't worked then try uninstail the dosbox and try reinstalling that hasn't worked either.
Reply 1 of 3, by J.B.
Try right-clicking the exe or the link to the exe and changing some of the settings from there.
I once had a similar problem when I switched the exe to windows 95 compatibility mode for a reason I can't remember and then forgot about it. Windows remembered this setting even when I had completly deleted and reinstalled dosbox.
