First post, by Longshot
😅 I'm sorry to ask what probadly is a noob question.
But i'm run in to a problem get Dos Box to work. I'm run the windows
version. It worked for the first couple of times untill i try to change the
setting for ems and xms. It had been loading as a small window in the
upper left side but after the change it's started to load in to full
screen and runs maybe to 2 sec before being shutdown. I've tried change
back to the default settings but that hasn't worked then try uninstail the dosbox and try reinstalling that hasn't worked either.
