First post, by xpid
In DOSBox Every program i run it says "illegal command" and my built-in DOS promopt has stopped functioning and it may no longer run MS-DOS and/or Microsoft Windows applications. wat's goin' on?,can u please help me? 😵
Eduardo Gonzalez
Reply 1 of 3, by Zup
I suggest you to post some extra data...
- Your systems specs.
- Operating system.
- DOSBox version.
- Configuration of DOSBox.
But, I think you have more problems than DOSBox.
DOSBox does not change your system configuration... or at least it is unrelated to you DOS prompt problem (I assume you are referring to cmd or command window).
Also DOSBox does not run any Windows program. It is possible, though, install Windows 3.0 or 3.1 on DOSBox and run some Windows programs, but DOSBox doesn't run Windows programs alone.
Reply 2 of 3, by Duncan Idaho
Sounds like viral activity to me, lots of older virii used to change all your shortcuts so your programs wouldn't run anymore. Just a guess, though, it could be any number of things.
