First post, by joe_pool_is
- Newbie
I have been unable to find any documentation on the [log] section in the dosbox.conf file (DOSBox 0.63). The closest explanation was found in the ChangeLog file. There are several settings that I am curious about:
- int10
- dma (direct memory access?)
- fpu (floating point unit?)
- paging
- fcb (file control block?)
- files
- ioctl (I/O control)
- exec
- dosmisc
- pit (programmable interval timer)
- keyboard
- bios
- gui
- misc
- io
Obviously, some of the terms I understand, but what do the true/false values change in the way the program behaves? For example, I set the value for keyboard=false and mouse=false, but I still had use of my keyboard and mouse.
The reason I ask is that my program does not run correctly if all values are set to true, but runs sluggish when all are set to false. Randomly changing values will take a long time to process.
If it helps, most of these values are loaded in the file debug_gui.cpp. A segment of its code follows:
void LOG_StartUp(void) {
/* Setup logging groups */
loggrp[LOG_ALL].front="ALL";
loggrp[LOG_VGA].front="VGA";
loggrp[LOG_VGAGFX].front="VGAGFX";
loggrp[LOG_VGAMISC].front="VGAMISC";
loggrp[LOG_INT10].front="INT10";
loggrp[LOG_SB].front="SBLASTER";
loggrp[LOG_DMA].front="DMA";
loggrp[LOG_FPU].front="FPU";
loggrp[LOG_CPU].front="CPU";
loggrp[LOG_PAGING].front="PAGING";
loggrp[LOG_FCB].front="FCB";
loggrp[LOG_FILES].front="FILES";
loggrp[LOG_IOCTL].front="IOCTL";
loggrp[LOG_EXEC].front="EXEC";
loggrp[LOG_DOSMISC].front="DOSMISC";
loggrp[LOG_PIT].front="PIT";
loggrp[LOG_KEYBOARD].front="KEYBOARD";
loggrp[LOG_PIC].front="PIC";
loggrp[LOG_MOUSE].front="MOUSE";
loggrp[LOG_BIOS].front="BIOS";
loggrp[LOG_GUI].front="GUI";
loggrp[LOG_MISC].front="MISC";
loggrp[LOG_IO].front="IO";
/* Register the log section */
Section_prop * sect=control->AddSection_prop("log",LOG_Init);
sect->Add_string("logfile","");
char buf[1024];
for (Bitu i=1;i<LOG_MAX;i++) {
strcpy(buf,loggrp[i].front);
lowcase(buf);
sect->Add_bool(buf,true);
Is there an updated help file that talks about what these individual pieces of the code do?
Wanted: Gasoline and matches.
