First post, by guest
🙄 I have a FUJITSU-SIEMENS laptop, Celeron 2.8 GHz, 256 M RAM, 64M (shared) on board video adaptor, 15" TFT screen, running Windows XP pro SP2.
When I try to run dosbox in fullscreen, I get fullscreen, but ROTATED 90 DEGREES COUNTERCLOCKWISE!!!
Does anyone know something about it?
Reply 1 of 8, by eL_PuSHeR
Did you tried tinkering with the options inside dosbox.conf?
Fullfixed, fullresolution and such.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 8, by `Moe`
Did you by chance swap width and height in your "fullresolution" option? And did you use your LCD's physical resolution?
If your native (maximum) screen resolution is 1024x786 pixels, use exactly that in fullfixed. Your laptop shouldn't be able to rotate that 😉
Reply 8 of 8, by eL_PuSHeR
Good to hear you got it solved but I would use frameskip=1 - You won't hardly notice any difference and will save a few cpu cycles.
Intel i7 5960X
8 GB DDR4 (2100)
