First post, by butterfly
Which version of DOSBox can be run under Solaris JDE? I did a search with Google and I found there was a non official JDS DOSBox version but I only found it on one site and the file has been removed.
Reply 2 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well you can't call those ports
dosbox compiles on most system that have an sdl port and a good c++ compiler (like gcc)
Water flows down the stream
Reply 4 of 7, by HunterZ
I call them ports because I'm pretty sure there's win32 and linux specific code in a few places...
butterfly: You can try getting a Solaris port of SDL and using that to compile the DOSBox CVS or 0.63 source.
