First post, by Onions91021
How can I view .bat files on the Android version of afreebox? I have messed around with it, but it doesn't seem to load the file up. Any help would be greatly appreciated.
Thanks,
Pepe
Reply 1 of 1, by DosFreak
A batch file is just a text file so any program on the host can open it. If you want to view the contents of a file in DOS you can use the Type command or install ms-dos or freedos edit.
For specific help with the version of dosbox you are using you'll need to contact the developer of that version.
Make your games work offline
