First post, by bubba
I have an old DOS application which is extreamly memory hungry. In order for it to function under Dos 5.0 it requires the following setting in config.sys which allows the program to also use upper memory to run.
DEVICE = c:\dos\himem.sys
DEVICE = c:\dos\emm386.exe noems i=a000-b7ff x=e000-efff
DOS = high, umb
FILES = 30
BUFFERS = 30
BREAK = off
DEVICE = c:\dos\smartdrv.sys 4000
SHELL = c:\command.com /p /e:1024
How can I emulate the same memory set up in dosbox. What edits are required to the dosbox config file ?
