First post, by malcolm
I have just discovered DosBox
I work on micro-processor development, some of which requires old Dos assemblers/compilers/emulators.
As my old Dos programs do not work under XP, I installed 0.63 on a Win2K machine. When I start up there is an error message box with 'The procedure entry point GetRawInputDeviceList could not be found in the dynamic link library USER32,dll'.
I can only asume there iis a version problem of some sort.
Any suggestions?
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
GetRawInputDeviceList is supported only since WXP... I have just now searched in the current CVS and it is not used there...
http://msdn.microsoft.com/library/default.asp … tdevicelist.asp
Looks like the build or some of supporting libraries you are using were made WXP only...
Mirek
