First post, by MJ
Okay, I am trying to install the 7th guest on my comp using dosbox but when I get to the part on the install screen where it says to pick a drive to install it to it tells me I haven't got enough free space to install it. Is there anything I can do?
Reply 1 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
I think helping the readme of dosbox helps a lot.
(hint look at the mount command)
Water flows down the stream
Reply 5 of 8, by `Moe`
And so spoke the Lord of all Forums: Thou shalt not poste while thou art asleep 😀
Reply 6 of 8, by eL_PuSHeR
E.g. mount c c:\ -freesize 850
That would create a C drive with 850MB capacity.
As stated, you have the following info in your README file (inside the folder where you installed DOSBox). Who would have guessed it? 😁
MOUNT "Emulated Drive letter" "Real Drive or Directory"
[-t type] [-aspi] [-ioctl] [-usecd number] [-size drivesize]
[-label drivelabel] [-freesize size_in_mb]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 8, by DosFreak
The readme should really be renamed to something more eye catching like:
Free Money
XXX-Britney Spears
Pics of your mom
etc
etc..
Make your games work offline
Reply 8 of 8, by US60
I have to admit, I found my info in the readme after I posted a question in the development forum and got it answered. There is a LOT of information in that file that can overwhelm the newcomer to DOSBox, but if you read the whole thing through without trying to scan over it too much, you will likely find what it is you need to know!
Thanks guys for your patience with us newcomers 😀
