First post, by Danido
Hi All,
I'm trying to run a very old Dos application with DosBox.
I can start the program but when I make a choice in the program I see the message:
Too many files at address 040B:7681
In my old config.sys (old dos-computer) I must write:
FILES=70
But DosBox has default 100 ?!?!
Why see I the error?
Can please anybody help me ??..
Thanks.
Danido[/b]
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
without the program itself we are quite clueless unfortunately.
you could try a cvs build to see if we have fixed the bug.
look in the development forum at the CVS builds by aep thread.
Water flows down the stream
Reply 4 of 6, by eL_PuSHeR
Danido wrote:
Yes, I've try that. This is my config.sys in the root of the mounted harddisk: […]
Yes, I've try that.
files=200
buffers=80
But with the config.sys I see the same error.
I don't get it. If you previosly stated that 100 files handles were too much, why are you specifying 200 now?
You should set...
files=70
buffers=30
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 6, by Danido
I don't think that 100 is to much, but the program must have a minimum of 70 files. Is it wrong to try files=200 ???
I've 2 questions:
1. Can anybody tell me what the error means? " Too many files at address.. "
2. Can I sure that a config.sys in the root of the mounted drive works ???
Thanks.
Danido
P.s. sorry, but my english is not good!
Reply 6 of 6, by eL_PuSHeR
OK, I understood you the other way around.
Is the program a clipper program by chance?
Try setting a variable of SET CLIPPER=F150
and specify a FILES=150 setting in config.sys
I have been good success running this type of apps. using VDMSound (Check the forum if you don't know what it is).
These are the settings I used under the Advanced -> DOS Environment of VDMSound shortcut.
FILES=150
FCBS=4
Good luck.
Intel i7 5960X
8 GB DDR4 (2100)
