First post, by Enator18
Hi, so I have come here from the doom community because I have not been able to get a good answer to this question there. So I like playing doom on dosbox for the authenticity that it provides, however, I am struggling with one issue that makes the playing experience much worse for me. I am having sound issues. The music works great, I am using virtualmidisynth for that and it is perfect quality and I have no issues with that. My problem is with the SFX. It is either very crackly or very delayed. The more sounds playing at once, the more crackly it is. I have tried many different values for the sound settings and I can't quite get it work well. Any ideas?
this is my config file:
[sdl]
fullscreen=true
fulldouble=true
fullresolution=3440x1440
windowresolution=original
output=openglnb
autolock=true
sensitivity=500
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=false
[dosbox]
language=
machine=vga
captures=capture
memsize=16
[render]
frameskip=0
aspect=true
scaler=none
[cpu]
core=auto
cycles=auto
cycleup=500
cycledown=20
[mixer]
nosound=false
rate=49716
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
device=default
config=0
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:ULTRASND
[speaker]
pcspeaker=true
pcrate=49716
tandy=auto
tandyrate=49716
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
ipx=false
[autoexec]
mount c .\doom2
c:
novert.com
doom2.exe
exit
