No COM ports
First post, by Edd
No COM ports support
Informer not diagnostic COM port
Help[/img]
Reply 1 of 15, by eL_PuSHeR
Surprisingly enough this is inside DOSBox documentation (Why was it hidden?)
[directserial] # directserial -- Enable serial passthrough support. # comport -- COM Port inside DOSBox. # realport -- COM Port […]
[directserial]
# realport -- COM Port on the Host.
# defaultbps -- Default BPS.
# parity -- Parity of the packets. This can be N, E or O.
# bytesize -- Size of each packet. This can be 5 or 8.
# stopbit -- The number of stopbits. This can be 1 or 2.
directserial=false
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1
I don't understand what you mean. Would you mind to rephrase using intelligible English?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 12 of 15, by taiken7
Thanks Hal; yes, I've also been using my own variant.
The problem is that the DS chipsets require REALLY accurate timing.
I was thinking of stubbing a little WinXX driver to assist, but I don't
think 6 months of work for a single application is going to be worth the effort.
