First post, by Guest
Im trying to play california games and it says im running 203k short of having enough memory but i've changed the config to 500mb of memory and i know that game doesn't use 500mbof memory
The config? Where did you change the config to 500mb of memory?
Have you tried running "loadhigh" before playing the game?
i changed dosbox.conf to
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=100
By the way i changed the mem to 100 not 500
Try the loadfix command, it works well.
i type it in and it says 64kb allocated and i need more
never mind it works!!!
I thought 63MB was the max supported by DOSBox.
It is. Dunno where these people get the idea of putting higher numbers in there. Should probably mention the max in dosbox.conf
#memsize= Min=x Max=x
well dosbox turns it into something sensible regardless what the user sets 😀
Qbix
