First post, by Eric40
I was using DOSBox several times over the weekend to play a DOS game. I have a SONY Vaio laptop computer. I was using DOSBox again on Monday night and the machine crashed - it just turned off while in use and didn't turn on again. Ever.
Reply 1 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
I doubt that dosbox is to blame
maybe your pc overheated ? Did you overclock it or so ?
Water flows down the stream
Reply 2 of 9, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
No, DOSBOX did not crash your machine... It is a relatively simple program, which does not install anywhere deeper into system (no shared DLLs, no drivers).
And in any case: no program should ever destroy hardware (I understand that your comp does not work at all). Well, there were some viruses - but that's different.
When you go with you daughter in your car and it suddenly breaks down, do you blame her for breaking the car?
Mirek
Reply 3 of 9, by Zup
Try this:
1.- Unplug your Vaio from any power adapter.
2.- Pull off the battery of your computer.
3.- Wait some seconds... or some minutes...
4.- Put on the battery and try to turn on the computer.
I don't believe DOSBox is related to your problem... it could be a hardware problem or a windows crash.
I'm selling some stuff!
Reply 4 of 9, by Eric40
I think it overheated. I waited a while for it to cool down to restart it, but it never restarted. I went through a troubleshooting procedure on the phone with a computer tech person from Circuit City Computer Support Plus. There was nothing that got the computer started. I sent it to get it fixed. Hopefully the hard disk is alright. I can't do a darn thing about it if the data was lost. I thought DOSbox was good for playing games. It worked nicely. I know that it didn't cause a Windows crash. The thing overheated or something went wrong with the hardware.
Reply 5 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
yeah dosbox uses a lot of cpu power.
If you have a cooling problem then when you run dosbox it might show up.
Reply 8 of 9, by DosFreak
Not really. Download a program like SpeedFan or Motherboard Monitor and see if it can monitor your computer internal temperature and/or CPU temperature while using DosBox.
Make your games work offline
Reply 9 of 9, by Snover
vaio: expensive crap. 😀
I would have suggested applying pressure to the memory sockets to see if that got it working. Those solder joints go bad all the freaking time.
Yes, it’s my fault.
