First post, by Vicrry
My joystick seems to work fine, except that the dead area is fairly large. It won't do fine adjustments, it only moves when the joystick is pushed far over and the cursor moves too fast.
Reply 1 of 6, by eL_PuSHeR
What type of joystick do you have? Analog (old) joysticks tend to be bad for DOSBox while USB ones are way better.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 6, by eL_PuSHeR
I don't know. Maybe Qbix or some other knowledgeable person might shed some light on this issue.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
uhm is the joystick calibrated correctly within the game.
futher. Try a cvs version as a lot has changed to the joystick code in dosbox. You can find more information about cvs in the development forum.
Water flows down the stream
Reply 6 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Any idea why the joystick doesn't work correctly in Crusader: No Remorse/Regret? The Remorse one comes with the attached joystick test program and I can't get it to calibrate correctly.
    JOYTEST.EXE
    13.25 KiB
    161 downloads
