First post, by UnBeatWater
Hi,
I need to interface with a DOS app, it simply takes keyboard input (text mode).
And I would like to do it via an STDIN-STDOUT Interface.
Reply 2 of 7, by UnBeatWater
jmarsh wrote on 2023-08-08, 14:25:
DOSBox is only intended for games, not applications.
But the DOS-based app runs perfectly fine under DOSBox. Also if you're telling me that I shouldn't be using DOSBox for this, just give me a DOS emulator (I'm planning on installing FreeDOS in Qemu to get what I need) that runs on Debian GNU/Linux 12 Bookworm that uses a STDIN-STDOUT Interface.
Reply 4 of 7, by mkarcher
UnBeatWater wrote on 2023-08-08, 19:46:
I'll just use qemu.
If you are using Linux as operating system, you might also want to take a look into the dosemu or dosemu2 project. This is slightly more lightweight than using qemu.
Reply 5 of 7, by UnBeatWater
mkarcher wrote on 2023-08-08, 20:07:
I'll just use qemu.
Just making sure, does it support soundblaster? Since the app is an ancient speech synthesizer.
Reply 6 of 7, by mkarcher
UnBeatWater wrote on 2023-08-08, 20:14:
As we are currently in a dosbox subforum of VOGONs, we shouldn't discuss the alternative DOS emulation solution here in too much details, but yes: dosemu and doesmu2 do have soundblaster emulation. I was one of the primary developers that sent patches to dosemu to create usable soundblaster emulation in the late 1990s, but that code has since been re-written.
Reply 7 of 7, by UnBeatWater
mkarcher wrote on 2023-08-08, 20:29:
Great, I'll update the post title
