First post, by klinick
When I run DOSBOX it writes "failed to create a rendering output" and 5 sec after that app closed. What I have to do to run dosbox ?
(I try to run it at Pentium II 300 MMX) it too slow to run ? :>
A P2 300 is likely too slow to run at a decent speed. It should still work, though not very fast. A simple search of the forums yields some good threads:
Topic 9517 and Topic 9284, for example.
My site: Ramblings on mostly tech stuff.
thx.. sorry for write another post with same problem but I didn't found that links.. 😒
You should definitely read http://dosbox.sourceforge.net/wiki/index.php? … eDemandingGames as well, since I wrote that guide while I still used my P2-333. 😀
ok those topics artent there and more kepp so any where else with the answer to the question?
