First post, by humongaloid
I'm running xp on a pentium m 1.7
WHen i set up dosbox and follow the instructions, it informs me that the drive I'm trying to mount doesn't exist. I've re-read and re-tried the instructions several times with no luck.
I put the folder containing my games on c:\pcgold collection
Any help would be greatly appreciated.
Reply 6 of 17, by avatar_58
humongaloid wrote:
In response to Kippesoep, I've tried it both ways, with the same result.
Show me your my computer and drives....are you dead sure your harddrive is labeled "C:" in windows? Did dosbox give you errors on the mount command or only when you attempted to switch to that directory?
@Kipp - I always refer to C as "C:" since thats how it was in the dos days 😎 Dosbox accepts it either way....so I always use C: for the sake of it.
Reply 12 of 17, by avatar_58
In the future its best to keep your dos folders with short names and one word since thats how it was done in the "good 'ol days" and helps with old games that have issues seeing such complicated names.
