First post, by Gynvael Coldwind
Hi.
I'm running (compiled from source) Dosbox 0.63 on linux (2.6.12.3) with Xorg 6.8.2. The problem is that when I run it in fullscreen mode, i only get a small "window" (the rest of the screen is black) at the center of the screen. The resolusion doesn't change (I use 1024x768x24@85 at Xwindow, and have 640x480 set up in .dosboxrc), nor is the window "resized" to full screen.
I have tried many diffrent settings in dosbox (surface/overlay/opengl/openglnb, diffrent resolutions, diffrent "true/false" settings at some parametrs) but i can't get it to work.
The funny thing is that the same config with the same version of dosbox works fine at M$ Windows (the resolution changes, used a binary distribution thou). It also worked when i had linux (2.6.8) with Xfree installed (i've used dosbox 0.62 or even 0.61 back then). So I guess it's a problem with Xorg.
Oh, I have a radeon 9250 (with drivers from ATI installed).
Anyone had a similar problem maybe ? I could realy use some hints ;>
Thanks in advance =^^=
ps.
.dosboxrc
[sdl] fullscreen=true fulldouble=true fullfixed=false fullresolution=640x480 output=surface hwscale=1.00 autolock=true sensitivi […]
[sdl]
fullscreen=true
fulldouble=true
fullfixed=false
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=highest,normal
mapperfile=mapper.txt[dosbox]
language=
machine=vga
captures=.
memsize=32[render]
frameskip=2
aspect=true
scaler=normal2x[cpu]
core=dynamic
cycles=10000
cycleup=500
cycledown=20...
xorg.conf (just a pice)
Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" DefaultDepth 24 […]
Section "Screen"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
SubSection "Display"Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Modes "1024x768" "800x600" "640x480" "320x240" "320x200"
Depth 24
EndSubSection
Viewport 0 0
Depth 32
EndSubSection
EndSection
gynvael.coldwind//vx
