First post, by Gamer725
I just want to ask a general question about dosbox versions. I already downloaded version .063 which is working fine for the game I downloaded it for, but now I see another game I would like to download, but it says it needs dosbox version .61. So do I have to download dosbox version .61? Or does dosbox version .63 which I already have, include all previous versions of dosbox, and will it work for the game which says I need version .61 of dosbox?Thanks.
Reply 2 of 6, by Gamer725
I guess my message wasn't very clear. I mean that I am presently using dosbox version .63 which was listed as supporting the game I am presently playing in dosbox. Now, on the Dosbox site, I see a different game, called "Arthur, Excalbur" - forget the exact title, but doesn't matter as I am just using it as an example, and it says beside the title, "version .61 Dosbox", which I thought means you need to download version .61 of dosbox. Maybe I should ask this way - Why are different versions of dosbox listed beside different games? Hope this is more clear what I am trying to find out.
Reply 3 of 6, by HunterZ
It could mean many things. Some of the following come to mind:
- It could just be some random version that someone reported getting it to work with
- It could be the earliest version of DOSBox that supports the game
- It could be that the site is recommending it as the version to use (there may be glitches in 0.63 with that game)
I would recommend checking the compatability database as dosbox.sourceforge.net and/or just trying the game yourself in 0.63. The development of DOSBox and the VOGONS community support of it are both very active, so if you have problems with a game in 0.63 (the latest official release) then we'd appreciate knowing about it anyways.
Reply 4 of 6, by avatar_58
This is thing...perhaps we ought to tell people that those "Works since 0.61" actually means that it should work in anything higher as well (90% of the time)....because I think some users misunderstand and assume an older version is needed.
