First post, by shadowfax
Hi everybody,
I'm experiencing some problems with DoxBox with some games when they try to save configuration files to disk. A couple of examples are Larry 1 VGA and Larry 2. When running the install utility, they tell that there's a problem and cannot save configuration to disk. I've tried to select a certain amount of free memory in the config file with the -freesize parameter, but it seems that the problem is elsewhere. Does anyone know what's the problem and how to solve it?
Thanks
