First post, by Lahos
Hi.
I have a special problem.
I want to take screenshots, but not with pressing CTRL+F5. Because if I press any key, the game disappear the presentation screen, and goes to menu. I dont have time to take it. Is there any way to take screenshot by another way, for example the right-clicking of mouse? 😦
Reply 2 of 12, by wd
Rank DOSBox Author
DOSBox Author
Well pause the game (pause key) and make a screenshot
with your host OS (shift-print or something like that on
windows).
Might work best when dosbox runs in a window and not
in fullscreen.
...damn qbix was even faster...
but you cheated, you wrote much less text 😉
Reply 4 of 12, by HunterZ
Alt+PrintScreen is the Windows combo for taking screenshots of just the active program window. PrintScreen by itself will capture the whole screen (or multiple screens if you have more than one).
Reply 8 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
change the screenshot key in the mapper to plain f5
then you don't need to press control and the f5 key isn't send to the application
Water flows down the stream
Reply 9 of 12, by wd
Rank DOSBox Author
DOSBox Author
Hm, don't know what you expect it to look like, but at least
the palette should be the same.
Try to change the colour depth of your host OS (use 16 bit
or 32 bit) and maybe try to insert the screenshot into a
different imaging application (photoshop should work fine
for windows/mac).
Reply 12 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
really ? hmm weird. Then you have to bind it to the pause key.
That one is certainly not send as many people complain about that.
