First post, by eurorusty
I'm not understanding the instructions for the keymapper.
I deleted the existing mapping for VIDEO, I think, then I added SHIFT, CTRL, ALT, F5 and saved, but it seems to map to each key separately, so SHIFT runs the video capture, then SHIFT-CTRL turns it off, then SHIFT-CTRL-ALT turns it back on, after that it stays stuck on and won't turn off and I have to kill DOSBOX directly.
If someone can explain exactly what I need to map VIDEO to SHIFT-CTRL-ALT-F5 that would help a lot. I deleted the custom keymapper configuration file so can assume I'm starting from the default.
Alternatively, if there's documentation for the keymapper configuration file format, I could edit it directly and not deal with the confusing keymapper interface.
Reply 1 of 5, by BitWrangler
I'm a bit rusty but I think that's possibly interfering with some linux defaults that are used to switch consoles. i.e. another login/shell
Reply 2 of 5, by zirkoni
Map only the F5 key to Video, then select all the modifier keys (mod1, mod2, mod3) from the bottom left corner.
Ctrl + Alt + Fn changes the TTY on most Linux desktops, you might also want to change the modifier keys or use something like Ctrl + Shift + F5 (without Alt).
https://youtube.com/@zirkoni42
Reply 3 of 5, by eurorusty
In Linux, the default for VIDEO CTRL-ALT-F5 opens a login, so it has to be remapped to work with DOSBox. I tried remapping to all kinds of combinations of keys. I can't get it to recognize anything to make the VIDEO work. Whatever I save, the line for VIDEO is empty but the screen output still shows it as CTRL-ALT-F5. I'm not understanding why it's so hard to use. Is there documentation of the file format? Maybe I could just enter it manually.
Reply 4 of 5, by eurorusty
I think I figured out the key mapping file format. I did a random change so the mapping would be saved, then edited the file directly. For my system, "mod3" for SHIFT doesn't seem to work. Instead of the SHIFT-CTRL-ALT-F5 combination I saw recommended somewhere, I mapped VIDEO to CTRL-"Print Screen". Seems to work okay.
Reply 5 of 5, by eurorusty
FYI, DOSBox can run my demo program from 1992 which uses direct screen access, changing of frequency of the clock timer, calling INT for mouse info, and setting CTRL-BREAK interrupt handler – good stuff! For anyone interested, the GitHub repo is here: https://github.com/Russell-S-Harper/EXPLORE, and a video of it in action is here: https://www.youtube.com/watch?v=XTOIfkqW9O0. Thanks everyone for your help!
