First post, by Guest
Hallo,
how can I change my screen resolution in DOSBox or doesn't it go?
At the moment I only can change my window size widht the program d-fend.
Can anybody help by my problem?
Reply 1 of 5, by Kippesoep
Check the standard dosbox.conf. It describes two options, fullfixed and fullresolution in the sdl section.
I like to use:
fullfixed=true
fullresolution=640x480
My site: Ramblings on mostly tech stuff.
Reply 3 of 5, by Kaminari
Just a thought: if I create a custom 640x350 resolution via PowerStrip, will DOSBox be able to detect it as a usable screen mode for the EGA games that need it (instead of falling back to the typical 640x400 mode and displaying black bars at top and bottom)?
Reply 5 of 5, by robertmo
Kaminari: If you have an nVidia card you don't even need PowerStrip. Geforce drivers allow you to add almost any new resolution.
When I tried playing with rare resolutions i had to use multiplied resoluions (for example 1280x700) and I had to use appropriate dosbox scaler to force it.
This way I was even able to play Flashback (256x224) if fullscreen without any black boarders. I just added 1024x896 resoluion and configured dosbox with:
fullresolution=1024x896
output=openglnb
It worked perfectly even on an LCD monitor (with analog cable) 😀
(By The Way, Streatching 640x350 games to 4:3 screen will make them rather ugly.)
