First post, by deeped
Good evening,
Im here with my OPL problems again =)
firtly it succeed to "compile" fmopl to DLL so I can use it with delphi 😊
second, some simple test program sounded very good.
And the problem is now when Im trying to make my own DRO player. I attached the sample what my program produced, sadly its rubbish. Very bad result 🙁
still, DOSBO)( emulates it perfectly. Lets see what I do:
YM3812Init (2, 3600000, 44100);
YM3812UpdateOne (0, buffer, length / 2);
void WriteReg(port, val: byte);
YM3812Write(0, 0, port);
YM3812Write(0, 1, val);
if I just use "YM3812Write(0, port, val);" nothing sounds. Whats wrong? 😖
