Reply 40 of 110, by Dominus
- DOSBox Moderator
step 1. and 2. can be shortcut. We only took the long route because I didn't know you wanted a portable, not fully featured one (and to make sure that this works first before proceeding)
so it would be:
1. Install macports, in terminal run the commands
sudo port install libsdl +universal +no_x11
sudo port install libpng +universal
sudo port install pkgconfig +universal
Step 2. is not necessary anymore (unless you installed libsdl_sound or libsdl_net before)
