Reply 180 of 203, by lil_stenly
Two bugs found
When I use -freesize command jdosbox just quits.
When set the cputype to 386 there pile of errors appears in the console.
Booting without using -bochs boots fine, booting in 386 cputype with -bochs command throws that.
DOSBox version 0.74.27 Copyright 2002-2010 DOSBox Team, published under GNU GPL. --- CONFIG:Loading primary settings from config […]
CONFIG:Loading primary settings from config file F:\Torrents\Games\DOS\java\.dosbox\dosbox-0.74.conf
DOSBOX_RealInit
About to allocate memory 22543kb: 34005kb free
HARDWARE_Init not finished yet: NO SCREEN SHOTS
Keyboard AUX emulation enabled
MIDI: Using Soundbank: default
DSP:Reset
Read from port 378
Read from port 379
Read from port 3bc
Read from port 3be
Read from port 278
Read from port 279
INT10_Init
Invalid type for serial1
Invalid type for serial2
Parsing command line: AUTOEXEC.BAT
Special file open command 80 file Z:\AUTOEXEC.BAT
Parsing command line: SET BLASTER=A220 I7 D1 H5 T6
Startup time: 313ms
Parsing command line: cputype 386
Execute z:\config.COM 0
Parsing command line: imgmount A .//PM805.IMA -t floppy
Execute imgmount.COM 0
IDE: index 0 slave=false
Mounted FAT volume is FAT12 with 2863 clusters
Parsing command line: boot -bochs FD
Execute boot.COM 0
IDE: Adding IDE controller to port 0x1f0/%03x IRQ 1014
IDE: Adding IDE controller to port 0x170/%03x IRQ 886
$Revision: 1.209 $ $Date: 2008/06/02 20:08:10 $
Writing 0 to port 80
Activated
AUX Activated
Reset, disable scanning
Clear buffer,enable Scaning
Read from port 37a
Writing df to port 37a
Writing aa to port 378
Read from port 27a
Writing df to port 27a
Writing aa to port 278
Writing 2 to port 3f9
Read from port 3f9
Writing 2 to port 2f9
Read from port 2f9
Writing 2 to port 3e9
Read from port 3e9
Writing 2 to port 2e9
Read from port 2e9
VGABios $Id: vgabios.c,v 1.67 2008/01/27 09:44:12 vruppert Exp $
VBE Write 0=45248 eip=0x8a88
VBE Read 0 = 45248 eip=0x8a78
VBE Write 0=45252 eip=0x8a88
VBE Bios $Id: vbe.c,v 1.60 2008/03/02 07:47:21 vruppert Exp $VBE Write 4=0 eip=0x8b48
DOSBox switched to max cycles, because of the setting: cycles=auto. If the game runs too fast try a fixed cycles amount in DOSBox's options.
Starting rombios32
ram_size=0x01000000
CPUID
at jdos.cpu.CPU.CPU_Interrupt(CPU.java:1093) at jdos.cpu.CPU.CPU_Exception(CPU.java:1019) at jdos.cpu.CPU.CPU_Interrupt(CPU.java […]
