First post, by folavo
I have an ATI 9800 and I was able to run Dosbox 0.61 with OpenGL output but with the latest CVS ( 25-06-2004 ) it crashes with this error:
Fatal Signal: Segmentation Fault ( SDL Parachute Deployed ).
The instruction at "0x5ed26e18" referenced memory at "0x00000564". The memory could not be "read".
I have tried runing it with diferent SDL.DLL files with no luck.
I have tried an older ATI driver and again had no luck.
