First post, by Dos Game Player
I've just starting emulating Amigas using WinUAE and a very interesting option appeared: JIT (Just In Time Compiler) Apparently it sorts out the problem with lack of speed. A JIT system is just what you could need in DOSBox so you can get those demanding games running smoothly and sort out the jittery sound problem. You could also make a JIT.BAT in the Z drive to manage the JIT compiler settings.
If the developers think this is a good idea and want to implement it then I would contact Toni Wilen on his e-mail (twilen@sci.fi). Please note! He's from Finland. Oh! And he did not make the compiler. He has just used in in C programming
