Bug report: CGA emulation broken in DOSBox 0.62
First post, by Minuous
Games such as Bricks, Round 42, Moonbugs, etc. which use the CGA 16-colour mode don't look correct anymore under 0.62, they looked fine under 0.61.
Also the handling of the Caps Lock key is incorrect, as can be seen by trying to play Bricks.
Reply 1 of 29, by MabusRaeen
Strange Round 42 works wonderfully on my machine (0.62).
Try fiddeling with fullfixed/aspect/scalers
Maybe that will help.
Author of D-Fend, a DOSBox frontend.
D-Fend homepage.
http://members.home.nl/mabus
Reply 2 of 29, by Minuous
Nope, Round 42 is no good for me anymore 🙁 Are you using the default settings, or did you have to change something to get it to work?
I will have a fiddle as you suggest, but these games never needed fiddling under 0.61...I really think something in the CGA emulation subsystem must have been broken during the upgrade to 0.62.
And I *still* can't play Bricks regardless of graphics issues, due to the Caps Lock problem 🙁
Reply 3 of 29, by Minuous
I should point out that the graphics effect seen with these games is IIRC the same as with old versions of DOSBox such as 0.58 thru 0.60 (I think). This was fixed for 0.61 and unfixed for 0.62 🙁
The keyboard handling has *always* been buggy, though it is slowly getting better (eg. Ins key is now handled properly) 🙁
Reply 4 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
did you set machine to cga ?
0.61 dosbox came with a auto sensing default
now it defaults to a vga machine
see dosbox.conf for details.
Water flows down the stream
Reply 5 of 29, by priestlyboy
An interesting an example of all the video modes is to try each of them on Ultima6.
(There seems to be some bugs in Hercules when exiting Ultima6)
Ultima6 supports Hercules, Tandy, CGA, and VGA/MCGA.
Ieremiou
Helping Debug DOSBox.
Reply 6 of 29, by Minuous
I set it to CGA in dosbox.conf and now the graphics work fine. Thanks.
Once the Caps Lock handling is fixed it then will be fully playable.
Reply 7 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
hmm thought it was implemented right. Will have to look up the game to see what it expects 😉
Reply 8 of 29, by Minuous
OK, thanks. Here it is in case you don't have it.
Reply 9 of 29, by MabusRaeen
@Minuous
Just out of curiosity. Did you ever make it through Round 42?
D-Fend homepage.
Reply 10 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
capslock handling is a bug of sdl.
it doesn't report a capslock up.
(as it only reports state changes. so capslock on and capslock off)
I have no idea why they do that. (or it least did that.) but that's why capslock is behaving differently.
Reply 11 of 29, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Just thinking - what about using key mapper to map CAPS LOCK on another key? Then you will be able to play.
Disclaimer: I do not remember now whether it is possible to remap CAPS LOCK in keymapper...
Mirek
Reply 12 of 29, by Minuous
Only about halfway IIRC...
Maybe I will finish it soon though...might set CPU cycles to 50 😀
Will try using the keymapper and report back.
Reply 13 of 29, by Minuous
Although Caps Lock is theoretically supported in the keymapper, it doesn't actually work in practice for that key.
Also since I have started experimenting with the keymapper I am getting a lot of "segmentation fault - SDL parachute deployed" messages, either when loading DOSBox, when trying to bring up the keymapper window, or when exiting DOSBox. Although sometimes it works fine. Odd.
Reply 14 of 29, by priestlyboy
That's because of a bug that wasn't caught before DOSBox 0.62 was released.
It's been fixed in the Sourcecode.
Ieremiou
Reply 15 of 29, by Minuous
I have also found another CGA emulation bug, this one occurs in Frogger. In DOSBox in CGA mode, the blue river background moves about instead of being still. (In DOSBox in VGA mode, the wrong colour palette is used and the river background is black (ie. not present) - same as when run directly from Windows 98, and probably in MS-DOS).
Reply 16 of 29, by Srecko
ICON doesn't work with machine=cga in 0.62 (and later CVS).
With machine=vga it works fine.
Reply 17 of 29, by robertmo
i suppose you have a version which was "patched" by Mok so that it works in vga
Reply 18 of 29, by Minuous
Yes I do, does anyone have the unpatched version please? Doesn't look like he patched it too well 😀
Reply 19 of 29, by jal
MabusRaeen wrote:
@Minuous
I did. In fact, I once made it three time round before dying. Didn't happen often though 😀.
JAL
