First post, by fish
A lot of people seem to wish using Game Wizard or similar software in dosbox. It doesn't work. Dosbox's around quite some time until now. I think if it was easy to get these pieces of software to run, you would have done it.
Now what would be the clever way to go? write a dosbox-compatible freezer application? or is there a plugin api that enables me to write an external module? This way I could avoid taking up conventional memory (which was an issue with some games like st. thomas that needed about 600 k conventional memory).
Reply 1 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox has a debugger from itself. that one can not freeze memory but that functionality would be easy to add(as the debugger can allready break on memory changes)
most freeze application use the debugger registers on the cpu.
They are almost never used in games (maybe some extreme encryption/cdrom protection maybe)
Water flows down the stream
Reply 2 of 16, by robertmo
You can just use GameWiz32.
Reply 3 of 16, by fish
STORE function doesn't work with DOS programs.
Didn't in native win98 either.
Reply 4 of 16, by fish
Qbix, does your post mean debugger registers are not implemented in dosbox [yet] ?
You mean, those programs would run if dosbox had these registers added or are there other parts which would need to be added?
Reply 5 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
dunno. debug registers are the most important.
but they will not be added i think. (might slow down a lot things.)
just stick to the dosbox debugger.
that one is much more powerful 😀 as it's completely in control of the machine (even time stops 😀
Reply 6 of 16, by wd
Rank DOSBox Author
DOSBox Author
To run gamewizard, you need to edit int10_memory.cpp,
fct INT10_SetupRomMemory and change (at the beginning)
int10.rom.used=2; (was 3)
Don't ask why.
Then set up gamewizard with "video swapping=fast" as this
will use registers instead of an (unsupported) int10 call.
Now it should be possible to run it to some degree (could
crash every now and then, stuff not working etc.).
The memory freeze does a pretty simple thing, they check
the locations periodically and re-init them. This way
you don't get "hard"-frozen values as with debug regs,
but it works with games.
hth
Reply 7 of 16, by wd
Rank DOSBox Author
DOSBox Author
Hm, forgot about that ems bug...
use ems=false or put the following into ems.cpp
static Bit8u EMM_AllocateMemory(Bit16u pages,Bit16u & dhandle) {
if (!pages) return EMM_ZERO_PAGES;
if ((MEM_FreeTotal()/4)<pages) { return EMM_OUT_OF_LOG;}
Bit16u handle=1;
while (emm_handles[handle].pages!=NULL_HANDLE) {
if (++handle>=EMM_MAX_HANDLES) { return EMM_OUT_OF_HANDLES;}
MemHandle mem=MEM_AllocatePages(pages*4,false);
if (!mem) E_Exit("EMS:Memory allocation failure");
emm_handles[handle].pages=pages;
emm_handles[handle].mem=mem;
dhandle=handle;
return EMM_NO_ERROR;
Reply 8 of 16, by HunterZ
wd: Are these just workarounds to beat DOSBox and gamewizard into working with each other, or should some of this code actually be officially integrated into DOSBox?
Reply 9 of 16, by wd
Rank DOSBox Author
DOSBox Author
The first one is a workaround, as dosbox looks
correct there. I debugged this some time ago,
but didn't get to the real cause, i think they
need the vga characters at a specific position
or so.
The second one is an ems bug in dosbox, i
guess it wasn't added because it did not turn
up somewhere else (or my fix was odd or i
forgot to send it 😉
Reply 10 of 16, by fish
Applied the patch. Still likes to hang up but in whole it runs. Thank you very much.
Reply 11 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
wd wrote:
The first one is a workaround, as dosbox looks correct there. I debugged this some time ago, but didn't get to the real cause, i […]
or so.
forgot to send it 😉
I've never seen it. at least I don't remember it.
Reply 12 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
well the ems patch seems to be correct.
it's stated clearly in ralphbrown that the handle only gets changed if there is no error.
modified ems code to match this behaviour.
Reply 13 of 16, by AlecTricity
is this now incorporated in the standard build?
Reply 14 of 16, by HunterZ
Yes, I see it in the CVS changelog:
2005-01-12 13:44  qbix79
* src/ints/ems.cpp: Allocate memory changes handle only on succes.
This was after 0.63 was released, however, so you'll need to use a CVS build to have the fix.
Reply 15 of 16, by wd
Rank DOSBox Author
DOSBox Author
Suppose it doesn't work though, see the int10.rom.used=2;
thing above.
Reply 16 of 16, by fish
With both patches applied, Game Wizard 3a Pro did run and executed most functions properly. In some cases it did odd things to the display - that's just like it behaved on 286.
Still, I'd prefer a built-in method but the thing I started is lost with my broken computer. It was ill-designed anyway. When I have something ready to present, I will present it.
The Sole Survivor.
Find me on efnet #oldgames
