First post, by Sverx
Hi there,
I hope that's the right place for that info.
I remember that one game I had years ago had a stupid "copy protection system" : it does a check if a particular cluster in the floppy was marked as a bad one or not. It should have been marked as bad.
I went here on this website and I found it in your list: it's "Captain Blood" and it says it's "broken". So I gave a look into the DOSBox 0.63 source code and I see that the BIOS function "verify" (of INT 13h) isn't still implemented.
Unfortunatly I can't check myself because I no longer have that floppy with the game but I think that game and maybe some other will run ok if you add that real function... and have the original floppy 😀
Bye
Sverx
