SEGABRT (6) on DosBox
First post, by kmikhail
Hello!
[1] Initial report: https://bugzilla.suse.com/show_bug.cgi?id=1019083
[2] coredump and backtrace: https://bugzilla.suse.com/attachment.cgi?id=713776
Can someone help me to investigate this ABRT bug? Thanks!
Reply 1 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
from the backtrace it seems like dosbox is trying to shutdown. But maybe the stack is already to corrupt to exit (frame #6 is E_Exit).
So doom2 with plutonia.wad doesn't work correctly in dosbox. (at least with the auto/dynamic core)
Water flows down the stream
Reply 2 of 9, by kmikhail
One more thing here - on my side it reproduces only on 29th level of D2 Plutonia. Have no idea why is it so, but it is so.
Reply 3 of 9, by blue-green-frog
Test with music playback over General Midi (port 330 in dosbox).
Reply 4 of 9, by kmikhail
Done by setup.exe in D2: General Midi, 330. Result: no music in game, but no hangs, no sig_6 on 29th level and other similar items.
Reply 5 of 9, by blue-green-frog
Result is from user error:
Above backtrace:
CONFIG:Loading primary settings from config file /home/k_mikhail/.dosbox/dosbox-0.74.conf
ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)
MIDI:Opened device:none
http://askubuntu.com/questions/79944/dosbox-has-no-sound
Reply 7 of 9, by blue-green-frog
Dosbox 'general midi' is not configured.
Reply 8 of 9, by blue-green-frog
If soundblaster music is preferred over general midi, then purchase a version of doom2 that can be updated with a fix for the music bug:
https://doomwiki.org/wiki/Versions_of_Doom_and_Doom_II#v1.7
And the web site for the patches:
http://www.doomworld.com/classicdoom/info/patches.php
"Note: there is -no- patch for Doom2 v1.666 dated 8/25/94."
Reply 9 of 9, by kmikhail
Ok, thanks for help!
