Extending DOSBox debugger
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby DrMefistO » 2017-6-17 @ 22:17
I have few questions:
1) Where I can found amount of available memory during this running session? I mean count in bytes;
2) Launched executable segments information: I need to know segments information for the launched executable (code segment range, data segment range, etc., names);
The main goal of my efforts will be good IDA Pro debugger plugin for MS-DOS, without stupid bugs, and also extended DOSBox debugger itself.
DrMefistO
Re: Extending DOSBox debugger
Postby ripsaw8080 » 2017-6-17 @ 22:50
1) If you mean free conventional memory, that can be determined from free memory blocks: try the debugger's DOS MCBS command.
2) You seem to want features of a source-level (symbolic) debugger; but the DOSBox debugger is system-level.
User avatar
ripsaw8080
DOSBox Author
Postby DrMefistO » 2017-6-17 @ 22:59
1) I mean some structure in DOSBox source code from which is possible to get this info.
2) Info from DOSBox source code.
DrMefistO
Postby ripsaw8080 » 2017-6-18 @ 00:16
I guess look in dos_memory.cpp and dos_execute.cpp; but I'm not sure what you're looking for. Again, don't expect to find any source-level info about programs running within the emulation.
User avatar
ripsaw8080
DOSBox Author
Postby DrMefistO » 2017-6-19 @ 11:26
For example, I want to know in which address my program will be loaded? Where I can find the load address of the launched executable?
The main purpose of my project, as I mentioned before, is to create debugger plugin for the IDA Pro. I will embed debugger server into DOSBox, and it will response with memory info, segments info, registers info, doing steps, etc.
http://www.osdata.com/system/physical/memmap.htm#MSDOS regarding thing memory table: is it possible to know size of the 0x600 region?
DrMefistO
Postby Mok » 2017-6-19 @ 14:57
Isn't there something similar already (I have never tried it though)? https://github.com/wjp/idados
User avatar
Mok
Postby DrMefistO » 2017-6-19 @ 16:35
Mok wrote:Isn't there something similar already (I have never tried it though)? https://github.com/wjp/idados
I know this project, but this is exactly what I'm thinking about it: "stupid bugs".
DrMefistO
Postby binarymaster » 2017-8-01 @ 13:40
by Stas'M
User avatar
binarymaster
Postby jez » 2017-12-26 @ 23:30
Correct me if I'm wrong, but doesn't the full version of IDA (needed for the DOSBox connector) cost about $3000?
== Jez ==
User avatar
jez
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 2 guests
