First post, by cyberwalker
I got page faults while compiling C++ files in Borland BC4.52
and Microsoft VC1.52 on the latest CVS build. I have tested
the same files on DosBox 0.63 release and found no this issue.
I hope the next release will fix it.
Reply 1 of 15, by Qbix
Rank DOSBox Author
DOSBox Author
indeed interresting.
did you try it with core_full as well ?
Water flows down the stream
Reply 2 of 15, by cyberwalker
I have tested all the three cores. All give the same result.
Can I use paging.cpp of 0.63 release in CVS?
Reply 3 of 15, by HunterZ
It's worth a try. It may be useful to do a diff and see if anything sticks out.
Reply 4 of 15, by wd
Rank DOSBox Author
DOSBox Author
Also could you post some debug logs?
Reply 5 of 15, by cyberwalker
Here is the image of debug session.
Reply 6 of 15, by wd
Rank DOSBox Author
DOSBox Author
Does it behave if you set the memory to some large values
like 64 or so? And did exchanging the paging.cpp-file
(maybe cpu.cpp as well) work?
If you have a debugger-enabled compile (that is the dosbox
debugger) you can generate debug logs that contain some
information about the pagefaults (have a look at paging.cpp
to have it output even more infos like register values).
wd
Reply 7 of 15, by cyberwalker
wd wrote:
If you have a debugger-enabled compile (that is the dosbox debugger) you can generate debug logs that contain some information a […]
wd
To keep the exe file small, I build DOSBOX with required options only.
Even so, the release target produced by VS2005 is almost 900K. As I can debug it within IDE, I don't want to build it with debugger-enabled.
No. I did the tests on default settings come with CVS builds.
Reply 8 of 15, by cyberwalker
Yes. You are right. I replaced paging.cpp with the one from 0.63 release and did a CVS build. It works.
Reply 9 of 15, by wd
Rank DOSBox Author
DOSBox Author
The VS-Debugger is no replacement for the dosbox debugger.
The latter is capable of debugging the dos-applications (in
your case BC4/VC1.5) and supplies additional information
like unemulated aspects.
If you can provide either debug logs of the dosbox debugger
running the program, or examples (like the executables needed
to reproduce the problem, but be aware of copyright issues)
it might be possible to fix it.
wd
Reply 10 of 15, by HunterZ
cyberwalker: So the next thing I'd try is to see what changed in that file between 0.63 and CVS that might cause the behavior you're seeing.
Reply 11 of 15, by cyberwalker
I think you are right, but I don't understand paging of DOSBOX.
Reply 12 of 15, by Qbix
Rank DOSBox Author
DOSBox Author
I got bc5 and that one still works
maybe you can attach a sample sourcefile ?
as I did a mere hello world
Reply 13 of 15, by cyberwalker
The test source requires Borland Power Pack, it can not be built in BC5.x. I have got the log files by paging.cpp of CVS and 0.63 release(Thank wd). The log files are attached to the original post.
Reply 14 of 15, by Qbix
Rank DOSBox Author
DOSBox Author
Rumours have it that wd fixed the problem. It should be in the cvs source.
Reply 15 of 15, by cyberwalker
Yes. I am testing this fix. No issues found as yet.
