DOSBox ECE (for Windows & Linux)
Reply 260 of 1550, by telanus
wonder if someone could point out what I'm doing wrong. I'm compiling on Ubuntu 16.04. Most of the errors so far I was able to fix, but this I'm not sure how:
In file included from voodoo_opengl.h:33:0,
from voodoo_opengl.cpp:28:
voodoo_vogl.h:28:34: error: ‘void (* glActiveTextureARB)(GLenum)’ redeclared as different kind of symbol
extern PFNGLACTIVETEXTUREARBPROC glActiveTextureARB;
In file included from /usr/include/SDL/SDL_opengl.h:46:0,
from voodoo_vogl.h:24,
from voodoo_opengl.h:33,
/usr/include/GL/gl.h:1971:23: note: previous declaration ‘void glActiveTextureARB(GLenum)’
GLAPI void GLAPIENTRY glActiveTextureARB(GLenum texture);
voodoo_vogl.h:29:36: error: ‘void (* glMultiTexCoord4fARB)(GLenum, GLfloat, GLfloat, GLfloat, GLfloat)’ redeclared as different kind of symbol
extern PFNGLMULTITEXCOORD4FARBPROC glMultiTexCoord4fARB;
/usr/include/GL/gl.h:1999:23: note: previous declaration ‘void glMultiTexCoord4fARB(GLenum, GLfloat, GLfloat, GLfloat, GLfloat)’
GLAPI void GLAPIENTRY glMultiTexCoord4fARB(GLenum target, GLfloat s, GLfloat t, GLfloat r, GLfloat q);
voodoo_vogl.h:30:37: error: ‘void (* glMultiTexCoord4fvARB)(GLenum, const GLfloat*)’ redeclared as different kind of symbol
extern PFNGLMULTITEXCOORD4FVARBPROC glMultiTexCoord4fvARB;
/usr/include/GL/gl.h:2000:23: note: previous declaration ‘void glMultiTexCoord4fvARB(GLenum, const GLfloat*)’
GLAPI void GLAPIENTRY glMultiTexCoord4fvARB(GLenum target, const GLfloat *v);
from voodoo_emu.cpp:81:
Show last 39 lines
voodoo_emu.cpp: In function ‘void init_fbi(voodoo_state*, fbi_state*, int)’:
voodoo_emu.cpp:566:14: error: ‘FALSE’ was not declared in this scope
f->vblank = FALSE;
voodoo_emu.cpp: In function ‘UINT32 register_r(UINT32)’:
voodoo_emu.cpp:2784:25: error: ‘TRUE’ was not declared in this scope
update_statistics(v, TRUE);
Makefile:438: recipe for target 'voodoo_opengl.o' failed
make[4]: *** [voodoo_opengl.o] Error 1
make[4]: *** Waiting for unfinished jobs....
Makefile:438: recipe for target 'voodoo_emu.o' failed
make[4]: *** [voodoo_emu.o] Error 1
mv -f .deps/dbopl.Tpo .deps/dbopl.Po
make[4]: Leaving directory '/home/user001/src/dosboxece/src/hardware'
Makefile:458: recipe for target 'all-recursive' failed
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory '/home/user001/src/dosboxece/src/hardware'
Makefile:436: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/home/user001/src/dosboxece/src'
Makefile:377: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/user001/src/dosboxece'
Makefile:318: recipe for target 'all' failed
make: *** [all] Error 2
Reply 261 of 1550, by Yesterplay80
The voodoo patch included in this build doesn't work for Linux, because of some differences between OpenGL for Windows and the one for Linux that are beyond my comprehension. There is another patch that works for linux, though: VIDEO - 3dfx voodoo emulation (SDL1)
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 262 of 1550, by telanus
is there a way to compile without the voodoo patch
Reply 263 of 1550, by Yesterplay80
Not without rebuilding the entire code with all the other patches, which partially would have to be changed as well because they all are build upon another.
Reply 264 of 1550, by Ant_222
Maybe it is worth while seek help of the maintainer of that patch?
Reply 265 of 1550, by telanus
It seems that the patch is no longer capable of being merged with the current branch 😢 😕
Reply 266 of 1550, by Marty2dos
Do you plan add regular the OpenGL shader part to your builds? I seen a old version "DOSBox r4006 ECE (with GLSL shader)"
and please, dont hardcode the path to the user/appdata/dosbox/. You can add a Shader main path in the Dosbox.conf. 😀
Reply 267 of 1550, by Yesterplay80
No, I prefer going with the pixel perfect patch and both patches together doesn't work.
Reply 268 of 1550, by Ant_222
Classic DOS games are the last thing I should use a pixel shader for. On the other hand, with some help and patience I could re-implement my patch as a pixel shader. On the third hand, however, built-in hardware scaling in SDL 2.0 is the best way to go. Edit: It has support for integer scaling factors.
Reply 269 of 1550, by lukeman3000
Hey Yesterplay, I downloaded the most recent version of ECE and I get the following error:
"The code execution cannot proceed because libfluidsynth.dll was not found. Reinstalling the program may fix this problem."
Reply 270 of 1550, by Yesterplay80
Sorry about that, the file actually was missing from the folder that gets zipped and uploaded, I fixed this. And here's the missing file:
libfluidsynth.zip
141.64 KiB
170 downloads
Reply 271 of 1550, by Yesterplay80
That could be an alternative, if performance wouldn't suffer this could kill two birds with one stone.
Reply 272 of 1550, by micmic
I have a Win98 image that official Dosbox 0.74 boots fine from, but the latest version of Dosbox ECE can't boot it. I use the following lines in both cases:
imgmount 2 windows98.img -size 512,63,255,522 -t hdd -fs none
boot -l C
Dosbox 0.74 mounts and boots perfectly. ECE mounts the image and gives the message "Drive number 2 mounted as windows98.img". But with the boot command it returns "Error loading operating system. Setup cannot continue."
What am I doing wrong ?
Reply 273 of 1550, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Probably don't mix it. Install anew with ECE
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 274 of 1550, by micmic
Can't do that because ECE fails to assign a drive letter to the image.
"imgmount c windows98.img -size 512,63,255,522 -t hdd" returns: "Can't create drive from file". While with "imgmount 2" it mounts ok, when I give a letter I see this error (probably the same problem I see in this thread: "Can't create drive from file")
The same with any new hdd image I create (with other dosbox versions since ECE doesn't support the imgmake command)
Reply 275 of 1550, by ripsaw8080
Rank DOSBox Author
DOSBox Author
AFAIK, 2 GB is the largest image size that actually works in official source -- a limit of the C runtime library file functions being used. So, not an issue with the ECE build in particular, and your claim of a 4 GB image working in 0.74 seems... questionable. There's a patch to allow images larger than 2 GB, which is likely in the Daum builds: Large HD images (DOSBOX)
Reply 276 of 1550, by micmic
4GB works fine with official Dosbox 0.74, I have installed Windows 98 normally and on top of that several programs which work fine. At times I have almost completely filled the whole 4GB too (with CD images etc). I can upload the image somewhere for someone to test it.
ETA: I'll check again the dosbox version I've been using.
Reply 277 of 1550, by Myloch
I've never used dosbox ece: I have some questions
1. The situation with ECE's internal munt, is it on par with current munt sourceforge releases?
2. Can I still hook external wrapper nglide to this branch of dosbox, like I used to do with ykhwong's builds and dosbox-x ones?
3. Does it support ps1 audiocard like ykhwong or dosbox-x?
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 278 of 1550, by Yesterplay80
Myloch wrote:
I've never used dosbox ece: I have some questions […]
1. It uses the libmt32emu form the current version 2.2.0, so yes.
2. No, kekkos patch is an completely internal wrapper that "translates" Glide calls into OpenGL calls, so no external wrapper is needed or supported
3. No.
Reply 279 of 1550, by micmic
Ok, ripsaw8080 was right. It was indeed a Daum build the one that was working with the 4GB image. It's just that I've used so many builds that I've lost count.
So I guess I'm out of luck if I want the Pixel Perfect patch with my 4GB image, unless of course I try to somehow merge the two builds myself...
