First post, by M-HT
I created a backed in the dynrec for 64-bit ARM (ARMv8, little endian).
Detection in configure is included, but in case it doesn't work, following definitions should be set in config.h
#define C_DYNREC 1
#define C_TARGETCPU ARMV8LE
#define C_UNALIGNED_MEMORY 1
Patch for revision 4112 is in the attachment.
Changed files:
src/cpu/core_dynrec.cpp
src/cpu/core_dynrec/Makefile.am
configure.ac
New file:
src/cpu/core_dynrec/risc_armv8le.h
Reply 1 of 6, by bruenor41
Tested last day on 6 different devices and 20+ games. No crashes or unusual behaviors. Most important : No performance regression against 32 bit backend! Good work! 😀
Reply 2 of 6, by krcroft
This excellent work just future-proofed dosbox on aarch64 when it will eventually displace the 32bit arm archs.
Excellent addition!
Reply 5 of 6, by M-HT
Thanks to more testing by bruenor41 a bug was found. The fix is in the attachment.
