First post, by bthiry
hello,
running some programs developped for DOS on Windows 7 in DOSBOX 7.4 I noticed that
dosbox does not recognize the sort order parameter sent of the DIR command. Dosbox returns
'ILLEGAL' then my program crashes...
for example sendind the following parameter to the dir command is not recognized :
DIR /O-d
Any chance to have this fixed ?
best regards,
Benoît
Reply 1 of 9, by mrau
your syntax is wrong, not sure thats the solution though
Reply 2 of 9, by realnc
The syntax looks right to me. /OD would sort by date, /O-D would reverse sort by date.
But yeah, DOSBox does not support most of the MS-DOS options of DIR.
Reply 3 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
It could be added, but it is not very high priority feature to add at the moment. It's not very difficult to add.
Water flows down the stream
Reply 4 of 9, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Use the 4DOS, Luke.
Reply 5 of 9, by bthiry
Hello,
if it is not very difficult to add, I would really appreciate if you could implement it!
I confirm the syntax is as described by "realnc"
Anyway, thank you for making this program available, it's really a great tool!
Benoît
Reply 6 of 9, by dr_st
ripsaw8080 wrote:
Use the 4DOS, Luke.
+1
What he means is that you can run the 4DOS.COM command interpreter from inside DOSBOX, and then you get the standard command switches.
Actually you can even run COMMAND.COM and DIR /O works fine; however, I don't know what can break if suddenly DOSBOX does not implement all the internals of MS-DOS the way COMMAND.COM expects...
Reply 7 of 9, by bthiry
thanks for the hint! I will try it and let you know ...
Benoît
Reply 8 of 9, by bthiry
Hello,
I tried launching 4DOS.COM from inside DOSBOX. It works indeed and the dir command
works fine, but unfortunately when 4DOS is loaded, my program looses all its graphic capabilities...
Benoît
Reply 9 of 9, by bthiry
actually 4DOS completely corrupted DOSBOX.
I had to reinstall DOSBOX to have it working correctly.
Benoît
