First post, by Sal Z
Hi there!
Is it normal that the XMS support is not working in the CVS Builds?
I've tried the AEP, gulikoza and ykhwong CVS builds and all of them have the very same problem: trying to run ANY programs (except some readme scripts) with XMS enabled just give no response: any application just goes back to DosBox Command Line, without any error message.
Even a clean build done with the sources taken from http://pcnwstage.phys.rug.nl/ (just bare emu, no png, no SDL_net, nor SDL_sound) and MSYS give the same wrong behaviour.
DosBox 0.63 gives no problem, even with xms enabled.
At the same time , some applications entirely stopped working: stunts (patched with neverlock) gives back an error message while it ran perfectly with Dosbox 0.63 (look at the screenshot)
Any Idea?
By the way, I'm using a Duron 1400mhz with 512 MB of RAM, Radeon 9250 with the latest drivers and an Asus Nforce A7N266-VM (latest driver and bios, too) on winXP SP2
Here is the Config:
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullfixed -- Don't resize the screen when in fullscreen.
# fullresolution -- What resolution to use for fullscreen, use together with fullfixed.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# hwscale -- Extra scaling of window if the output device supports hardware scaling.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lower,normal,higher,highest.
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
fullscreen=false
fulldouble=false
fullfixed=false
fullresolution=1024x768
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,advmame2x,advmame3x,advinterp2x,interp2x,tv2x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: simple,normal,full,dynamic.
# cycles -- Amount of instructions dosbox tries to emulate each millisecond.
# Setting this higher than your machine can handle is bad!
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=normal
cycles=3000
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Enable MPU-401 Emulation.
# intelligent -- Operate in Intelligent mode.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device.
mpu401=true
intelligent=true
device=default
config=
[sblaster]
# type -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# base,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# oplrate -- Sample rate of OPL music emulation.
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# base,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# rate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# Tandysound emulation is present if machine is set to tandy.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true
[bios]
# Nothing to setup yet!
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
xms=true
ems=true
[modem]
# modem -- Enable virtual modem emulation.
# comport -- COM Port modem is connected to.
# listenport -- TCP Port the modem listens on for incoming connections.
modem=false
comport=2
listenport=23
[directserial]
# directserial -- Enable serial passthrough support.
# comport -- COM Port inside DOSBox.
# realport -- COM Port on the Host.
# defaultbps -- Default BPS.
# parity -- Parity of the packets. This can be N, E or O.
# bytesize -- Size of each packet. This can be 5 or 8.
# stopbit -- The number of stopbits. This can be 1 or 2.
directserial=false
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
mount C "J:\Documents and Settings\Salvo\Documenti\DOSC"
#mount D D:\ -t cdrom -usecd 0 -ioctl
SET PATH=C:\COMMAND;C:\DOS32A
keyb it
C:
    109.13 KiB
Reply 3 of 8, by Sal Z
You are right, it's keyb.com fault.
Well, to say it better, it's while using keyb.com that the problem arises, while it was perfectly fine with dosbox 0.63.
using "LOADHIGH keyb it" solves the problem , or just version 2.00 pre-release 4 fixes it.
very weird.
Anyway, if someone wants to take a look, here is it.
    KEYBOARD.zip
    36.38 KiB
    147 downloads
Reply 5 of 8, by Sal Z
pr3 works fine, and pr4 as well i think.
Sorry if I sound rude, but...are you sure of that?
I mean, actually it's the pr3 release of keyb.com that creates such memory problems, and the pr4 Changelog says clearly:
FIX: Correctly restoring the allocation strategy (bug notified by the DOSBOX team, THANKS!)
that seems like the situation shown here!
In any case, I 've not used the pr5, and i'm surely not going to use it and maybe break other things. 😀
Reply 7 of 8, by wd
Rank DOSBox Author
DOSBox Author
The analysis is still around somewhere, the bug i'm talking of is in
the UMB handling of keyb. As dosbox0.63 doesn't have UMBs, this
will not be noticed.
Yet pr3 worked fine for me, but of course it could be that something
is broken in dosbox. Or maybe i'm confusing the version numbering
of keyb somehow 😉
