64-bit dynamic_x86 (patch)
Reply 100 of 123, by Kerr Avon
jmarsh wrote:
Trying to emulate an entire 32-bit x86 CPU on a 32-bit x86 CPU is awkward because most of it is unusable by user code; segment registers, system registers, even ESP is restricted from being freely modifiable. A 64-bit CPU has an extra 8 general purpose registers to help get the job done.
I see, thanks.
Reply 101 of 123, by latalante
The Mp3 Lame encoder very heavily uses the dosbox FPU functions (FPU_FLD_32, FPU_FST_32), it doesn't show the difference between Intel Xeon and Core 2 (coding times under 64-bit dosbox are very similar).
However, the Dhrystone benchmark performs much better, it clearly shows the disproportions.
Reply 104 of 123, by Kisai
Compiling x64 on MSVC 2019 appears to not generate working binaries.
Exception thrown at 0x00007FF74F572C59 in dosbox.exe: 0xC0000005: Access violation writing location 0x000000009DAF9040.
The program '[51828] dosbox.exe' has exited with code 0 (0x0).
1>vga_memory.cpp 1>\src\hardware\vga_memory.cpp(961,55): warning C4311: 'type cast': pointer truncation from 'Bit8u *' to 'Bitu' […]
1>vga_memory.cpp
1>\src\hardware\vga_memory.cpp(961,55): warning C4302: 'type cast': truncation from 'Bit8u *' to 'Bitu'
1>\src\hardware\vga_memory.cpp(961,73): warning C4312: 'type cast': conversion from 'Bitu' to 'Bit8u *' of greater size
1>\src\hardware\vga_memory.cpp(965,49): warning C4311: 'type cast': pointer truncation from 'Bit8u *' to 'Bitu'
1>\src\hardware\vga_memory.cpp(965,49): warning C4302: 'type cast': truncation from 'Bit8u *' to 'Bitu'
1>\src\hardware\vga_memory.cpp(965,67): warning C4312: 'type cast': conversion from 'Bitu' to 'Bit8u *' of greater size
	Bit32u vga_allocsize=vga.vmemsize;
// Keep lower limit at 512k
if (vga_allocsize<512*1024) vga_allocsize=512*1024;
// We reserve extra 2K for one scan line
vga_allocsize+=2048;
vga.mem.linear_orgptr = new Bit8u[vga_allocsize+16];
vga.mem.linear=(Bit8u*)(((Bitu)vga.mem.linear_orgptr + 16-1) & ~(16-1)); //line 961
memset(vga.mem.linear,0,vga_allocsize);
vga.fastmem_orgptr = new Bit8u[(vga.vmemsize<<1)+4096+16];
vga.fastmem=(Bit8u*)(((Bitu)vga.fastmem_orgptr + 16-1) & ~(16-1));
I'm not sure if I missed something.
#define C_TARGETCPU X86_64
and
#define C_FPU_X86 0
are set in config.h
OK, Solution found in Benchmarking emulators on latest machines
The default config.h in SVN needs to be fixed to build
#ifdef _M_X64
typedef unsigned __int64 Bitu;
typedef signed __int64 Bits;
#else // _M_IX86
typedef unsigned int Bitu;
typedef signed int Bits;
#endif
https://sourceforge.net/p/dosbox/code-0/HEAD/ … isualc/config.h
    buildlog.txt
    34.23 KiB
    58 downloads
Reply 106 of 123, by Kisai
robertmo wrote:
That's what I linked to in the edit. I found it after when looking for other people's built versions.
Edit (Oct 21)
I managed to get this to compile (VS2019), and recompiled MUNT-SVN ( >2.3.0), FluidSynth( >1.1.6-noglib), SDL2 (2.0.11-snapshot), zlib (1.2.11), libpng (1.6.38-SVN snapshot), in 64-bit in a static build.
C Preprocessor settings
MT32EMU_WITH_LIBSOXR_RESAMPLER;MT32EMU_BOSS_REVERB_PRECISE_MODE;MT32EMU_USE_FLOAT_SAMPLES;ZLIB_WINAPI;DSOUND_SUPPORT;FLUIDSYNTH_NOT_A_DLL;WIN32;NDEBUG;_CONSOLE;%(PreprocessorDefinitions)
Libraries
dxguid.lib;Dsound.lib;Iphlpapi.lib;Setupapi.lib;Imm32.lib;version.lib;opengl32.lib;winmm.lib;zlibstat.lib;libpng16static.lib;sdl_net.lib;sdl2main.lib;sdl2.lib;pdcurses.lib;pdcurses-wincon.lib;fluidsynth1.lib;mt32emu.lib;libsoxr.lib;odbc32.lib;odbccp32.lib;ws2_32.lib;%(AdditionalDependencies)
    dosbox-32-r4275-20191020.zip
    1.76 MiB
    81 downloads
    Dosbox 32bit r4275-20191020
    dosbox-64-r4275-20191020.zip
    2.18 MiB
    66 downloads
    Dosbox 64bit r4275-20191020
Reply 107 of 123, by jmarsh
Would be interested to see some before/after benchmarks for this patch:
--- a/src/cpu/core_dyn_x86/risc_x64.h
+++ b/src/cpu/core_dyn_x86/risc_x64.h
@@ -468,7 +468,11 @@ static void gen_discardflags(void) {
static void gen_needcarry(void) {
- gen_needflags();
+ if (!x64gen.flagsactive) {
+ x64gen.flagsactive=true;
+ opcode(4).setea(4,-1,0,CALLSTACK+8).setimm(0,1).Emit16(0xBA0F); // bt [rsp+8/40], 0
+ opcode(4).set64().setea(4,-1,0,CALLSTACK+16).Emit8(0x8D); // lea rsp, [rsp+16/48]
static void gen_setzeroflag(void) {
Reply 108 of 123, by jtchip
Ryzen 5 2400G, DOSBox SVNr4296 built with gcc-9.2.1 on Fedora 31 x86_64, without and with the patch (had to restore the tabs the forum software converted to spaces):
D1:
Microseconds 1 loop: 2.88 -> 2.85
Dhrystones / second: 347826 -> 350877
VAX MIPS rating: 197.97 -> 199.70
D2:
Microseconds 1 loop: 2.98 -> 2.89
Dhrystones / second: 335518 -> 345479
VAX MIPS rating: 190.96 -> 196.63
Quake 1.08 (-nosound) timedemo demo1 (windowed on X11, output=opengl):
640x480: 76.9-> 83.1fps
800x600: 55.8 -> 61.0fps
1024x768: 37.8 -> 41.4fps
Reply 109 of 123, by jmarsh
Thanks. It seems the newer a CPU is, the worse performance it has for the POPF instruction (thanks a lot, speculative execution bug mitigations) so avoiding it as much as possible is a good idea.
Reply 111 of 123, by latalante
Intel(R) Core(TM) i5 CPU M 450 @ 2.40GHz
Linux 5.4.1
dosbox-svn-r4296, gcc-4.9.4, x86_64, (the second result with the patch applied)
D1:
VAX MIPS rating: 115.27 116.38
PCBench: 70.6 75.4
quake 1.06 with sound, demo1
320x200: 102.5 107.1
800x600: 28.4 32.8
Reply 112 of 123, by Firtasik
Firtasik wrote:
timedemo demo1
My own build (MinGW64), DOSBox SVN r4267 (x64) ~197 fps
jmarsh's SVN DOSBox (x64) ~195 fps
Official DOSBox 0.74-3 (x32) ~153 fps
EmuCR DOSBox SVN r4267 (x32) ~152 fps
Yesterplay80's DOSBox SVN r4267 (x32) ~147 fps
r4296 and the newest patch: ~206 fps
11 1 111 11 1 1 1 1 1 11 1 1 111 1 111 1 1 1 1 111
Reply 114 of 123, by latalante
realnc wrote:
i5 2500K (Sandy Bridge). Linux 64-bit. […]
Quake timedemo demo1 average of 5 runs each. cycles max, core dynamic.
Before: 105FPS.
After: 117FPS.
You could tell under what specific system you were running your binaries. Your results are unbelievably low compared to my older and much slower processor. The difference is around 9% should be at least in the range of 37-42% (if not greater).
https://en.wikipedia.org/wiki/List_of_Intel_C … microprocessors
Reply 115 of 123, by realnc
Gentoo Linux AMD64.
Edit:
Hm. I was using surface output and 1920x1200 window size 😜
I changed to openglnb, "original" window size and in-game res 320x200. Reran it:
Before: 121FPS
After: 131FPS.
Reply 116 of 123, by latalante
I tested the dosbox-staging version yesterday and the results were clearly lower than my build.
I upload my compilation here if anyone wants to compare.
https://drive.google.com/file/d/1L12wqanCgboj … iew?usp=sharing
It was built under the new version of the C library (glibc-2.30) and requires it. Under Linux, compatibility only works up.
Downward compatibility can be maintained by starting it with loading the necessary libraries.
If you have glibc-2.30, then just run like this:
cd dosbox-r4296
./bin/dosbox
otherwise
cd dosbox-r4296
./lib/ld-linux-x86-64.so.2 --library-path ./lib ./bin/dosbox
Reply 117 of 123, by krcroft
Do you mean dosbox-staging as in: https://github.com/dreamer/dosbox-staging? (Your shell commands show DOSBox SVN).
latalante wrote:
... the results were clearly lower than my build.
"the results".. which results - realnc's posted above your post?
"my build".. compiler, version, and optimization flags did you use?
"clearly lower".. (lower being faster? or worse? and by how much?) - can you list the actual before-and-after/A-vs-B numeric results and units for the benchmark?
Reply 118 of 123, by latalante
krcroft wrote:
Do you mean dosbox-staging as in: https://github.com/dreamer/dosbox-staging? (Your shell commands shows DOSBox SVN).
Yes
krcroft wrote:
"my build".. what architecture, compiler, and optimization flags did you use?
This thread is for 64-bit architecture.
Look here.
I use flto and others.
Lua, pcbench, lame, quake, ...
In each of my tests the difference was quite significant, at least 5-15% and maybe more. Maybe it's a matter of my old processor.
Reply 119 of 123, by krcroft
Thanks latalante, that helps.
I ran some tests and the two are roughly identical, within the noise of my system.
Can you try these steps? You can copy and paste them as-is into your shell.
Build the sources
wget https://github.com/dreamer/dosbox-staging/archive/master.tar.gz -O - | tar -zxC /dev/shm
wget http://source.dosbox.com/dosboxsvn.tgz -O - | tar -zxC /dev/shm
for d in dosbox dosbox-staging-master; do
cd "/dev/shm/$d"
./autogen.sh
export CFLAGS="-DNDEBUG -pipe -O3 -march=native -flto=$(nproc)"
./configure CXXFLAGS="$CFLAGS" LDFLAGS="$CFLAGS"
make -j$(nproc)
done
Install the benchmark
mkdir -p /dev/shm/dosbench
cd /dev/shm/dosbench
curl -sL https://www.philscomputerlab.com/uploads/3/7/2/3/37231621/dosbench_v_1.4_jan_2017.zip | busybox unzip -
Download the attached dosbox.conf and save it as-is into /dev/shm/dosbench
Benchmark Prep
1. Close all applications and confirm the system is idle
2. Open a new terminal
3. Lock your processor at its maximum frequency
echo performance | sudo tee /sys/devices/system/cpu/cpufreq/policy*/scaling_governor
echo 100 | sudo tee /sys/devices/system/cpu/intel_pstate/min_perf_pct
Benchmark
Launch each separately, ctrl+F9 when done, then run again.
../dosbox-staging-master/src/dosbox DOSBENCH.BAT
../dosbox/src/dosbox DOSBENCH.BAT
I ran:
- the landmark benchmark at 96400 DOSBox cycles (it wraps beyond that)
- the PC Player 3D benchmarks at default (low) and 640x480 resolutions
- Quake at default (low) resolution
510.78 KiB
Curious if this changes anything for you.
Oh, you can now let your processor relax 😀
echo powersave | sudo tee /sys/devices/system/cpu/cpufreq/policy*/scaling_governor
echo 1 | sudo tee /sys/devices/system/cpu/intel_pstate/min_perf_pct
    dosbox.conf
    617 Bytes
    111 downloads
