> is it a waste of users' time to report these bugs,
> since there is no interest in fixing them
Re-read the whole thread and have a look at how many people
tried to help you out, the only thing YOU do is insulting
them that they are too stupid to fix "your" bug.
Why don't YOU fix it? Dosbox is open source, so you can
contribute something instead of just requesting it.
> But it worked 100% OK on a genuine IBM-PC
As you can see from the version numbering of dosbox, it has
not yet reached that level of compatibility, because of
various reasons.
> Although Caps Lock is theoretically supported in the keymapper,
> it doesn't actually work in practice for that key.
It DOES work, just remapped it so tab can be used.
Works fine, 100% playable.
wd
